SOHC- How long does a water pump last? | Ford Explorer Forums
c_mccann
Long Beach, CA
'98 xlt
'98 XLT, SOHC, 2wd, auto 82k easy miles. Idling high, and the temp guage is a little higher than normal. Water pump time?? Thermostat? What is the lifespan of a pump? I flush the cooling system every year- nothing funny there, all other fluids done per the Ford reccommendations.
I'd start with a t-stat. Water pumps don't typically cause overheating problems (unless they develop a leak).
Have you cleaned or replaced the IAC. Other things it could be include P/S pressure switch, vacuum leak, or bad TPS.
