97pos
- April 3, 2009
- greenwood, in
- 97 explorer
Ok Ive read some of the posts here but not sure this is the death rattle cause its really not rattling. Its a 97 xlt with the sohc. Problem is it ran fine when we bought it and two days later it started idling rough in drive and sitting at a stop it sounds like its idling rough enough to die sometimes. The guy before changed the coil pack and I've changed plugs, wires and idler pulley. The codes are both saying spark problem and fuel problem. Those were common on both codes but there is others on each like vacuum and maf sensor. This thing is driving me nuts. The mechanic said replace plug wires try that. It helped some but still sucks. Its only a 3rd vehicle for us and has 107,000 miles. Any help would be appreciated. It also before the wires were changed looked like it needed a motor mount cause the engine shook alot. Also when you put it in gear it has a air flow sound that kind of sounds like a vacuum leak.
