GRNMACHINE
- September 11, 2000
- IL
- 95 Sport 4x4
$240 for 8 spark plugs.... Time for a new proctologist, I meant mechanic
Your mechanic (and Nordford) are giving you good advice here. Spark plug replacement on 06 and early 07 V-8 Explorer engines can be a real nightmare.
Do some research on this. Lots of info out there.
Mark: I hear you on this, I'm scared sh!!less about changing my plugs, but will have to take the plunge sooner or later.
Not sure what method you may be using, but I think that granadojl had great success with the WD-40. It must have soften the carbon and lubricated the threads at the same time. Makes me think that I will initally use the ford carb cleaner, then WD-40 or PB Blaster to lube the plug threads.
Keep us up to date and please post what method you used and what you would or wouldn't do the next time.
Thanks again for your post and best of luck.
willied,
That is wild, usually the dealerships want to "scare" you into getting services done way before they are needed. They usually dont turn down business. Before I started wrenching on my Ex I had the dealer change the front brakes at 36k (used to 90's GM cars-pads usually gone by 25k). They had no problem doing the work - they said pads werent really needed at 36k but whatever the customer pays for.
It is interesting. It seems like dealerships deny problems like this for whatever reason. All I know is that a local shop I got some work done at was aware of the problem and the guy said he had worked on like 4 or so Explorers with the problem, yet the lady at the dealer didn't even think it effected this engine. Beats me.
I found out about a little known problem by accident. I found out after I spent $800 bucks for a front cat section from dealership, that, if the left front cat went bad AT or BEFORE 80,000 miles on the 5.0 version. They would replace it free. But, if you got to 80,001, you were S.O.L.My light went on at 79,000 something then went off. Did not come back on til after the 80,000. I aske dif it was a recall, and of course they said no. When I pushed them the guy hung up on me.
I took my car in today to get the spark plugs changed along with a couple of other things. It's like $198 if they don't break any, which I'm sure they will.
I have NEVER had an issue with breaking a plug!!! All it takes is constant pressure with out going "Hog nuts" on them. If you need to use an extension, you need to put pressure in the opposite way you are pulling/pushing. For example; if you are on drivers side, all the way to the right, put your right hand under the head of the wrench, and as you pull down to the ground with your left hand, you push up with your right hand. Breaking plugs CAN be avoided. The key is to keep the socket from coming down on the end of the plug.
Other people have, though, so I have the right to worry. Have you done it on a 4th gen?
On a 4th gen... no. But, older more rusty gear up here in the salt and rust belt yes!
Not trying to offend you, BUT you need to realize what the problem is on the 3 valve motor in the 4 gens.(early 4th gens only)
Simply put, the spark plugs are 2 piece, there is a "long barrel" that extends into the head, this gets covered in carbon, literally seizes to head and brakes when removed.
Now you have a broken spark plug in the head with the threaded portion laying in your hand. See the problem now. How do you remove the barrel/sleeve and the porcelain.
