dbarconcepts
- July 20, 2012
- 2000 4x4 4 door
2000 4x4 expo. did an 1.5 shackle lift on my x all level side to side. Move on the the front and the passenger side ground to fender is 33 and 1/4 inch but the driver is 34 and 1/2 ground to fender. So i do the driver side and had to max the bolt out to get it to 34 1/2. so i got 1.5 lift in rear 1.25 on driver front and none on passenger side.
I read on here that having to install a 100mm bolt is common but i cant for the life of me see how a longer bolt will help get more lift. Also can any body give me an appx (i know there is no set ride height from ford) ground to fender height i should get after the bars are turned to 1.5 inch of lift using a 235/85-r15
