Someone i am begging you to help me!!! | Page 5 | Ford Explorer Forums
lol...I just read this entire thread waiting to get to the end to tell you it was the catalytic converter but you already figured it out. Had the exact same problem on a non-Ford vehicle when I was a student. Drove fine until you wanted to go up a hill. Eventually quite running all together. Replace the converter and added another year on the car before selling it.
Congrats on getting it fixed!
Related? Yes. But I doubt that any "contaminants" would have made it all the way through the filter, the rest of the fuel system, the injectors, survived the combustion process, and then made their way all the way through the exhaust, in a form large enough to clog the cat. I do believe that the plugged filter, and whatever caused it, could have caused a lean condition; enough to melt the cat(s). The bad fuel COULD have also traveled far enough to clog one or more injectors.
Like I said, I doubt this little saga is over.
if the contaminants caused it to run lean enough, that will melt a cat very quickly, acnd could have easily been the root cause. Ive seen that a few times working as an auto tech
New Videos
Don't know if it will Update my origional link but the 3 sensor check videos I made are up on youtube even tho you have fixed your truck Still good to know how to check your sensors or get your hubby to =Þ My original post was #78 but here are the Links to youtube Again so you don't have to go hunting I'll add more when I get the voltage info on remaining important sensors
http://www.youtube.com/watch?v=xz9uzl3iUvY MAF Sensor
http://www.youtube.com/watch?v=svh5VsWIEkQ TPS Sensor
http://www.youtube.com/watch?v=wyrDhudPWLU ACT Sensor
No one laugh too hard these are my first videos Hope Someone can use these some others I've seen weren't very helpful
lower intake gaskets?????????????
