surphrat420
- January 23, 2004
- sunny, florida
- '92 Eddie Bauer
OK bear with me..
This explorer is a 94 4x4 4.0 auto, its my backup truck
i only ride it around every 4 or 5 months, well used to, it doesnt fire up anymore. used to run fine never a single starting problem, one day after giving the battery a recharge it never started back up. The situation goes like this. new batt , key on, and i hear the fuel pump whirl for 3 sec. all dash indicates full power and function. the engine will crank and crank but never fire up, UNLESS i spray some gas into the TB. THis leads me to my problem NO fuel. So i purged the fuel via the purge valve (tire valve on fuel rail), well it squirt me in the eye, I dont have pressure gauge so I opened the valve and connected a container to the open relife valve and turned the key on and off and it filled up about 1/2 soda can in two key cycles. That seems like a good amount of gas? well I broke down the Top end removing the upper intake plenum and fuel rail itself to remove and clean the injectors, then i connected each injector to a 12v source to listen for a click, they all tested ok( as well as all checking for around 16 ohms). they were cleaned and every think was blown dry and reasembled. i get some votage on my digital multimeter at the injector harness plugs when i crank the engine( some voltaghe means the same result i usually get by tapping the leads onto a 12v source quickly removing them). This is driving me crazy, could all the injectors be very cloged?? all at once?? the presure regulator seemed to be stuck closed when the rail was off i pulled a 25psi vac on the vac line and i could not blow through the valve ( im not sure if that is how the regulator works anyways) could this be my problem? ANyways , ive tried every thing in the chiltons book with no luck , i ve tried alot more than i can write here, any one have any suggestions? Does a fuel pump go bad and only pump1/2 output , or do they usually just quit?
I guess next step might be getting a fuel pressure kit
thanks in advance
thanks in advance
