- April 25, 2000
- Houston, Texas
- 2008 JK
Before I begin: note: no maintenance or work has ever been performed on my truck without my knowledge and/or consent. I am the original owner.
Anyway, Splat has almost 60k miles and even though the maintenance book says to change the plugs every 100k I figured I'd get mine changed and go a heat range cooler for the s/c and n2o. All 6 OE plugs were pretty much shot, though after careful examination, just due to normal wear, and not fuel conditions or undue stress (except for 1 that was replaced 2 weeks ago from an accidental 200 hp shot
). It was just time for them to be changed.
Here's the weird part: the left side of the motor had double platinum motorcraft plugs, while the right side had single plat's. ??? The plugs hadn't been touched since the truck left the factory.
I dunno what's up with that.
Anyway, we replaced all 6 with double plat motorcraft plugs, 1 heat range cooler than stock. The truck runs great now, it's much smoother and a bit quieter. I even advanced the timing a bit (via the s/c computer) to take advantage of the new plugs. All in all, I'm very pleased. I've yet to run the n20 with the new plugs, but I'm sure it'll be better than before.
NOTE TO ALL X OWNERS: Do not follow the factory guidelines and replace your factory plugs at 60k, not 100k. Plug wires, too. My plug wires were replaced 18k miles ago with the s/c install. 8mm motorcraft heavy duty wires are fine.
Thanks for reading!
Thanks for reading!
