Txfireblade
- September 2, 2008
- McKinney,TX
- 2007 Limited 4x4
I thought I'd share my recent experience relating to the spark plugs in my 2007 Sport Trac 4.6 V8 just in case it helps anyone.
So I'd read about the problems with the 3 valve Ford V8's and how the plugs can become jammed in the heads once the mileage starts to build up. My truck had 43K miles on the clock and so I thought I'd pull the plugs so check for any carbon build up and hopefully prevent them seizing up. I removed the plugs successfully, although some of them were tight ,and I cleaned the small amount of carbon off the plug barrel. The plug gap look to be quite large but I couldn't find the spec anywhere (didn't check the hand book thoroughly enough) so I put the plugs back in (since they're supposed to be good for 100K miles and they can't be adjusted) and went out for a test drive.
I immediately noticed a misfire, followed shortly after by the check engine light coming on. I returned home, checked all the connections etc but the misfire was still there. I picked up a new set of plugs the next day and installed them, and the problem went away. When I went back and checked the old plugs again, I found that they all had started to fail, with the plug body starting to pull away from the center electrode. This is what caused the plug gap to increase when I removed plugs.
So just a word of warning, if you remove the plugs before their due time, expect to replace some or all of them as the removal process alone seems to trash them.
