I picked up some plugs the other day at autozone - got the motorcraft ones. So these aren't gapped for my truck and I'll have to gap them?
Also, should I go ahead and pick up the wire set? I have a 2005 with about 72500 miles on it. I think I should be getting the tranny flushed pretty soon, too.
Never flush a tranny...A pan drop/filter change/refill is fine, but flushing tends to do more damage than good. Others have done flushes with good results, but in my experience, about 50% of the vehicles serviced are worse a couple weeks later than they were before getting it done.
Multiple vehicles with the same symptom is more than opinion.
If it worked for you, great...Problem is, for the average Joe Schmoe, it's like flipping a coin as to whether or not it's going to yield the same results.
Isn't there a difference in how much fluid is actually changed in a drop vs flush? .
Is this on your used car lot? Maybe not the best location for a valad sample.
What are you basing that on? Data from a used car lot, or real world.
I'll be changing my plugs this weekend, I am far from being a mechanic and only have a few tools. I will post my fun when I finish... Also the fuel filter was a real pain enen with the tool.
