rmcknight
- December 10, 2005
- Melbourne, Australia
- 2004 4.6 SOHC v8 Explorer
Today i replaced the plugs on my 2004 2v 4.6 Explorer, after researching this forum i mustered up the courage and went for it.
Things worthy of note:
The vehicle had 105K on the clock.
The job was very easy, there was nothing tricky at all and each plug took about 5 to 10 mins, only because i was being very cautious.
I used Champion Iridium 9204 Plugs for $5 each. The old ones were NGK.
No need to remove the fuel rail, just the large air intake, in some cases i used the swivel joint though.
The old plugs looked quite used (except for the electrodes that all looked in great condition - i guess iridium does last!)
The 2v engine does not have the plugs that break in two.
Some were tight and im sure they would have broken in two if they could have...
I used the plug grease on the bottom of each boot coil inside the spring.
I did not torque to any specific point, just till it was quite tight.
After i removed each coil i vacuumed the hole and then again after i pulled each plug, that did a great job of cleaning up any dirt.
Regards, Ralph.
Regards, Ralph.
