Spark plugs and aftermarket wire for $145.00 | Ford Explorer Forums
m435tro
Colton, CA
2001 SportTrac
Hey guys..,
I just called local Ford dealer and asking how much to put on plugs and wires (aftermarket) and they gave $145.00 Is it worth it? Should I just go to PepBoys and have it done overthere? I figured they should now how to right? I mean I know ours is a little bit complicated (wheel well, etc). I wish I could do it myself but brrrrr, is too cold outside. ;) Let me know guys..!
thats a really cheap quote from the dealer- i know 3 or 4 years ago i let them do my plugs and they quoted me a ton more than that (but it was in for some warranty stuff so i let them do it)
for that kind of scratch I'll fly down there and do it!
No seriously that is alot of $$$$$.
What kind of plugs and what kind of wires?
You may have them install the plugs, but the wires you can do yourself and save some $$$$..
I like NGK plugs or Motocraft platinums.
I run the Bosch +4's in my 4.0L, but the others are good too.
Taylor makes a great custom fit high performance plug wires for your truck, for about $40 shipped to your door.
truckperformance.com
I bought Bosch +2 and bought Taylor wires from fellow member, Jim aka Stomper. So actually I suppose to pay the labor. Is that a good deal for $145.00?
$145 for labor?
thats 2 hours worth at a dealer, or 1 hour plus the basic shop charge.
I could change all 6 of your plugs and wires in about 30 minutes.
Going through the wheel well is the key for the pass side, it helps if you jack up the truck a little and have the right tools.
$145 is a good deal for the plugs, wires, and labor, but not just for labor, its about double what the job is worth
I beleive pep boys is somewhere around 65$ if you buy them there and 85$ if you don't. All i know is the dealer will probibly be the most explensive
:D you have a link to lingerie models in your signature:D
good work man!
I called another Ford dealer. They gave me $250 and when I said I got the plugs and the wires, they said the won't do it because is not Ford parts. You guys know why? Something I should now? Or that's just their marketing trick?
I don't know if it's a marketing trick, but even if you did supply ford parts, it would still be way to much. The price pep boys gave ain't to bad, but I wouldn't trust them with a broke ratchet!. They messed up my maxima just changing tires! I know it's cold, but you look better just changing them yourself, or waiting until spring if you can. The weather is supposed to be better in the tri-states in the next few days....
Its because they dont make any money installing other peoples parts.
You will find many shops dont want to install customer parts, most of the $$$ made in shops come from the mark up on the parts.
