ExplorerChrisWay
- February 3, 2000
Does anyone know where I can find clearances on clutch components within bell housing? I am just replacing the slave cylinder (it leaks.) I get the transmission down tomorrow (Friday) at school, and want to check all the parts before I put it back up to save further trouble. The entire system was replaced under 10000 miles ago, but the reason I want to check parts is because it has never worked correctly since it was replaced, and the only problem may not be the leaking slave cylinder. If anyone has input, or has any general suggestions, please post.
P.S. Does anyone know where I could get a master cylinder clutch rod? I had mine lengthened for a temporary fix, and now want it back to original length.
