Speed control ceased functioning on 2006 Explorer | Ford Explorer Forums
Eddiegilbob
Lansing, mi
2006 Explorer
I have been using speed control often for several years with no problems until a day ago. On the road, control working fine, the dash light went out and control just stopped. I wanted to check the fuse, but, my owner's manual gives no indication as to which in-cabin fuse is the right one. So, I checked each one. All are fine.
Any suggestions?
Eddiegilbob
The old models of cruise control used vaccum, but now I believe that they are pure electronic relying on feedbacks from a variety of sensors. The fuse box in the engine compartment may be where the fuse location for it is.
Here is a link on the Ford system. It looks like in 06 they are still using a vaccum setup so you may want to check for vaccum leaks in the primary system.
http://www.thorssell.net/hbook/ccexpl.html
