speed related clicking FL wheel | Ford Explorer Forums
JonsFolly
North Carolina
1991 Explorer 4wd
I just bought a '91 Explorer w/autolocking hubs, at, 4.0. When I tried 4x4 it didn't engage or disengage properly, I tried the reverse, etc, figured I could make it back home, about 4 miles from home I heard a pop and something fell off, brakes had to be pumped to work. 3/4 mi from home a scraping noise. when I pulled FL wheel, the hub came off and the 4x4 cam assembly was blown. Also missing the inner brake pad, had to replace caliper, pads,bearings, & converted to manual locking hubs. (passenger side was fine, but replaced pads & hub, repacked bearings). Used original seal because I bent new one when installing.
now has milemarker manual hubs, ($200 at the local parts store for the hubs and conversion kit). When I drive, it makes a clicking noise that increases/decreases relative to speed, goes away when braking. Would this be the brakes, wheel bearings, or the joint in the axle?
BTW, 4x4 also not engaging (tried on wet grass, rear wheels spun but front didn't) even tho light is coming on. Low Range won't even light the light.
Greetings and welcome to the site!
Below I have added a link for a great thread to help you out with your 4X4 issues. The clicking noise, I would jack up the front wheels and turn them to find out which one is clicking, then keep investigating until you find what it is. Sounds like it could be the brakes but you will figure it out. Use jack stands, safety first!
http://www.explorerforum.com/forums/showthread.php?t=202166
It was the left brake. I forgot the little clip on the inner brake pad, the old one was completely gone so I didn't have a reference, never had one like that before. Thanks for the tips, I will check out the shift motor later in the week when my daughter is out of the hospital and over pneumonia. Just like a majority of the posts, it clicks, the light usually lights, but no 4x4. Will let you know.
A speedy recovery to your daughter. I had pneumonia once, very unpleasant!
