speedo recalibration | Ford Explorer Forums
Bigcheck1
Marlton, NJ
2004 Nissan Xterra
quick question about speedometers.. i currently have 32x11.50 bfg's on my truck and need to find out how to recalibrate my speedo. anybody done this or know how to do it??? i wuold think it is relatively easy...at least i hope so. thanks guys
There is a gear that go's in the trans.that needs to be changed.I'm not sure how many teeth the gear is that you need.It takes just a couple of min.to change out.
cool, thats what i thought, anybody done this or a write up on it???
The gear is on the end of the speedo cable drivers side of the trans.There is a small plate with one bolt holding it on the trans.There is a clip that holds the gear on the cable.Change gear and thats it.
Check out TheRangerstation.com there is write ups for every size tire and ratio. The gears are color coated and you can get them from ford.
