speedometer work/stop/works | Ford Explorer Forums
LynnY
98Explorer XLT
Could the cruise control not working affect the speedometer working sporadically?
Yes
Welcome to the forum
If you post in the 95-2001 forum's you will get a much better response
Is there any kind of leaking around the sensor on the master cylinder?
Welcome to this forum! It's the opposite way around. If there's an intermittent issue with the speed sensor, then you will have issues with the cruise control. The speed sensor provides a signal for the speedometer, cruise control, ABS, and transmission shift points. Are you experiencing issues with all of these things? Does this only happen when you tilt the steering wheel? Sometimes the issue is in the steering column. Wires get damaged from tilting the wheel, then there are intermittent shorts against metal which is grounded. Other times it could be due to melted wiring against the exhaust, the speed sensor, the reluctor ring in the differential or even metallic dust which gets caught on the sensor from the brakes or from the differential. The sensor might need to be cleaned.
Yes, I am experiencing those problems also. Thank you so much!!!
no se si encontraste la respuesta sobre si afectaba al velocimetro pero como estan cerca lo mas seguro que si afecte por las revoluciones que no son las optimas o sobre todo que no te de una lectura clara pero eso deberias cambiar lo en algunas empresas de trabajo o empleo jaen te dan ese tipo de informacion para que no batalles mucho
