Spindle Nut Conversion, what do I need? | Ford Explorer Forums
dmaster79
Canton, OH
'01 Explorer XLS 4x4
I'm planning on buying the warn manual hubs to convert over from my auto on my '93 explorer. I understand there is a conversion kit I need to buy. My question is are they all the same, like if I buy Warn hubs vs the Mile Markers, is it the same kit. I found these on ebay http://cgi.ebay.com/ebaymotors/ws/e...&rd=1&item=7938591267&ssPageName=STRK:MEBI:IT
Is there any reason these won't work. Do these nuts ever wear out and is this all there is to the conversion kit, besides the socket? Any help would be appreciated. Thanks
That's all you would need, but without seeing them in person all I can say is they look like what my WARN kit contained. They say every time you remove the spindle nut you should replace it, so I'm not sure if buying a used set is completely safe.
The WARN and MM conversion kits would be the same, but WARN hubs are known for their quality, might be the same with their spindle nuts?
