1993xlt
- July 4, 2004
- Southern Illinois
- '93 XLT
I recently bought a 1993 explorer xlt and found that the front bearings were run loose for quite some time and spun on the spindle. I can't figure out how to remove the sensor thing (I don't know what it's called) for the ABS that is on the spindle. I took a bolt out of it from the outside of the backing plate, is there more? I used a slide hammer spindle puller and the side without the sensor moved, but the sensor side wouldn't budge.
Also, I will go junkyard shopping in the morning for another spindle, what different years and models (Ranger?) will have the spindle with the ABS that I need?
Please help the un-knowing, Thanks.
