Squeaking noise from the transmission | Ford Explorer Forums
Ahmedz
2009 explorer
I just noticed squeaking noise from under the transmission of my 2009 V6 explorer. I showed it to two different transmission experts, one said its the transmission converter which needs to be replaced. The other said its the transmission pump.
The noise pattern changes when I switch from P to R to N to D (while the car is idle), but it doesn't go away.
I am confused. Have you guys experienced such noise from your explorers?
No, but I would post this over in the transmission section to see what those guys over there have to say. Personally I would just start with a fluid change to see if that helps if you have never had it changed.
