Guam'sBest
- March 19, 2008
- Atl, GA via Tyler, Tx
- 02xlt
Not sure if it is coming from right or left side, but it's only when in motion. I sprayed the sway bushings with wd40 and it stopped for a day but came back. I bought some spray grease to lube my cracked upper control arm bushings and tried to spray the sways but since they aren't cracked it doest penetrate well (the stuff is kinda thick). Could it be power steering related if it only squeaks on right turns? It' a just driving me crazy.
Also (I'm going for a two-fer here), I'm getting serpentine belt squeaks that I think are near or at the attachment to the alternator. I need belt lube right? Guy I bought the explorer from said he replaced the belt around 90k and I'm at 115k now. On yeah, it's an 02 xlt 4x2.
Also, my power steering reservoir looks a little low. I read you guys put ATF in. Would it be ok for me to top off with ATF? Thanks guys
