06MountaineerPA
- August 11, 2013
- Philly, PA
- 2006 Mountaineer Premier
I have been battling this squeak for a month now. I have been told to check the body mounts and spray them with Silicone spray. Suggested to check the front suspension parts and everything looks good. I was going to replace the sway bar bushings and end links.
Yesterday when I jacked the front end up to do the oil, I heard the squeak as I was lifting the weight off the front wheels. Sounded it like came from the Lower Control Arm Bushing, mainly the big front ones. I tried spraying them and working my lil red straw into any little crevice I could get it into spray. Silicone spray was dripping alot. Was hoping that would solve it and it didnt. Maybe I didnt get it in deep enough. So now I left with replacing them.
Are they pressed in or is it easier to just replace the whole arm? Should I try spraying the upper control arm bushing?
