SRS Module | Ford Explorer Forums
SRS Module
johnmm
2004 Explorer Sport Trac
Where is the SRS Module on a 2004 Explorer Sport Trac? My airbag light contunues remains on and failed safety inspection
The light remains on after it's flashed the trouble code several times. prior to doing anything, count the flashes when you first turn the ignition on and report back here.
** **** ** **** ** **** is what you would see for code 24, for example.
Well, when you first turn the ignition on the light flashes (3) times for a serious of 5 sessions then remains on. It looks like a bear to get the module as well.
Do not mess with the module.
So it's ***_***____***_***____***_???
The codes are 2 digit codes. Based on your counts we will assume it's code 33 which is "Restraint System — Safety Belt Pretensioner Status (Driver Pretensioner Circuit Fault)"
Common cause is the connector under the drivers seat becoming disconnected. Check the yellow connector for a good tight clean connection.
