Stack 2 single AAL's from same manufacturer??? | Ford Explorer Forums
macker123
victoria, bc
97 Explorer Sport 4.0 OHV
I can buy an add a leaf locally so I don't have to pay shipping. They don't sell the double add a leafs though.
Can I just stack two single add a leafs together? They are from the same manufacturer.
I have tried searching and nobody has a definite answer.
You'll have to get a long leaf and a short leaf that are meant to be stacked together. You can't just stack 2 normal aals together.
See others on this board have said you can stack two aal's together as long as they are the same manufacturer. This is where the confusion comes in.
Well you can't just stack 2 identical aal kits together; simple as that. Like I said above, it is possible if you get one short leaf and one long leaf and they install in the same order as the double aal kit.
FYI: Pro-Comp double AAL kit ...
Part # 13135... if you call 4wheelparts.com you can special order it through them... thats where i got mine. comes to $125 or so after handling charges.
Mine will be here shortly.. after i install it ill let everyone know what i think. I just decided id rather pay the extra $30 to get the actual kit than risk doing something wrong with two different AAL's
