Hi all. We have a 2002 explorer v6 with about 150k miles on it. Over the last few months we have had an increasing common occurrence of the car stalling or not able to start. The check engine light is not on, and when it is running, it seems to run fine (no rough idle or anything out of the ordinary)
It seems to stall when coming to a stop, but it always has started right back up so far.
When we have had starting problems, it is usually after the car has been running for a few minutes, and then we turn the car off, and then when we try to start it back up, it won't start. The engine turns over normally, but just doesn't start. It acts like it is out of gas, though its not. Usually a few minutes later, it will start and then run just fine as it nothing happened.
Any ideas of what might cause this?
