Lochlain
- June 21, 2014
- Indiana
- 1996 Ford Explorer
Hello everybody, I'm new to the forum and a relative car novice and was hoping for some advice on what to check on a '96 Explorer that stalls in the heat.
It is my wife's truck, and it now sputters before stalling after being driven in the heat. It has not stalled driving 20 miles at 70 degrees or below, but will last maybe 3 miles when it is 90 degrees outside. I've noticed it is when the needle is about 25% between cold and hot on the temp dial that I have to start worrying.
I have replaced the coil pack, and it did not solve the problem. I've been told it may be the crankshaft sensor but the symptoms I read online don't seem to match. The only other symptom I notice is it will sputter maybe 30 seconds before it stalls. It will not start again after stalling for 20 minutes.
I suspected the fuel pump but it was replaced 18 months ago, and car guy pal says probably not the pump because strainer valve had gas flowing.
I can't afford to take it to the shop for another month so I'd appreciate any ideas! The only other info I have is that the wife says it has stalled on her before going 50, though I've only had it happen while idling. It also started this on the day she accidentally drove it in 2nd gear for 10 miles (going around 45-50mph for a good part of that).
Thanks for any help!
