sierraoneill
- March 30, 2009
HI all,
I have a 99 SOHC explorer, just shy of 200k miles, and recently (this winter) developed a starting issue.
I was fearing fuel pump, but I think I’ve ruled that out as it will start and run as normal when getting it going with starting fluid.
When diagnosing the fuel pump I went for the quickest easiest fix and replaced the fuel pump relay, which seemed to make things better, but may not changed anything as the temperature was in the 50’s. Now that it’s even colder out (20-30’s, only way to get it started is by using starter fluid When it is “sat overnight cold”
My searches on the forum have had me get an Intake Maniforld gasket kit (upper and lower) which I now have in hand ($15 so I like the price on this fix so far).
Question is before I spend several hours replacing them, should I replace anything else at the same time I have the Intake all disassembled?
Any opinions that I may be going not going about this the right way?? If it needs a new fuel pump, I would likely have to take it to a mechanic as I would have difficulty dropping the tank to replace it…which may mean junk yard for the old car given the cost of having someone do that work and the values of the car.
Thanks in Advance!!
Thanks in Advance!!
