RevLuvv
- October 22, 2010
- Albuquerque
- 99 Explorer EB
I have a 99 explorer with a weird starting problem. With a full battery( measured voltage and placed it on a starting charger) -- I place key in ignition. turn to on position. gauges fire up but voltage is low. I turn the key and total discharge ( no lights or indicators in cabin) It will not reset. I remove battery terminal, wait replace it and the interior lights come back on. I repeat with the same results. The night it first happened it started but while depressing the gas the voltage showed a huge drop. At idle, the computer stated voltage OK. I found it odd and turned it off for a restart. When I did I experienced the problem listed above. Any ideas?? Relays??
Thanks in advance!
Patrick:
Thanks in advance!
Patrick:
