Starting issues | Ford Explorer Forums
Starting issues
Dr rob
94 ford explorer 4x4
I've recently replaced my fuel pump, filter, plugs and wires but it still won't start. Battery and starter are also brand new and so is the coil pack. Anyone have any ideas or may have had the same problem and was able to figure it out and fix it? I'm not a mechanic obviously but I do know a little but I'm at a loss.
Was it running before you started all the work? Try spraying starting fluid in the air box to verify spark. It will kick over but not start. If that works you still have a fuel problem. Check pressure at the fuel rail to the injectors to confirm fuel flow or disconnect the filter and turn on the key to be sure the new pump is working.
Check the "Inertia" switch.
It is a fuel cut-off breaker that is triggered on impact (and various other mystery reasons).
Located: passenger foot well on the fire wall. Big red button... .
I figured it out, it was the crankshaft sensor that was bad, but all the parts I replaced over the last 2 wks I was gonna do anyway so all is well, problem has been taken care of. Next project is the shocks front and rear and the a/c needs a new line
