mndeerslayer
- December 6, 2003
- MN
- 02 SportTrac
I'm having a problem with starting my Sport Trac that I hope someone can help with. During cold starts (more than 1 hr after last use) the engine turns over but will not start unless you use the accelerator. Then it requires about 10 seconds of maintained pressure (~1000rpm) to get the engine to idle correctly. After that, no prob. Doesn't even occur every time which adds to the confusion. My mechanic is baffled as well. We've added injector cleaner with no effect. I'm assuming this isn't a fuel filter or pump problem since it runs fine after starting. Possibly a leak somewhere in the fuel system but why doesn't it occur every time? No know recalls on the Ford website for this model either. Any ideas????
