johnwartjr
- December 28, 2009
- Columbus, Indiana
- '96 Limited
96 Explorer limited, bone stock
Around 150k on the odometer, been in the family since new.
Has a starting problem.
It starts just fine every time if it's been sitting for more than about 40 minutes.
So, it starts fine in the morning, starts fine when my wife leaves work.
But, it acts funny if you try to start the engine within 40 minutes or so of shutting it off.
She has to time her stops carefully, because if she stops the truck somewhere, she knows she has to be there for at least 40 minutes.
When you try to start it, it may start, and then die immediately. Almost sounds like it's choking for fuel. Symptoms remind me of vapor locking. But, it happens regardless of the temperature.
So far, I replaced the fuel pump relay, because I read a few places it could be that. Didn't help.
I have a new motorcraft fuel filter and the tools to change it, just need to find somewhere to change it as I don't have anywhere at home I can lift cars off the ground.
I've read it could be the fuel pump, too. I don't have a fuel pressure gauge, but I don't understand how it could be the fuel pump or the filter, and it works when it's been sitting for 40 minutes or more, but not immediately.
Am I working the right direction with my troubleshooting, or is there something else I should be looking at?
Another odd hint that I should throw out, as I've had to sit in this thing in a few parking lots before, waiting. Right before it will start, I hear a clunk noise from the drivers side of the truck, in front of the firewall.
Also, if I go for a very short drive in the morning, say 5 miles or less, where the truck doesn't get up to operating temperature, I can run in a store, come out, and it will start.
