timysully
- September 13, 2014
- spencer tennessee
- ford explorer
i have a 94 explorer stock 4.0. i went mudding in it the other day and got in it next day to go back but it would not start. i changed the starter still nothing. i also noticed that whin i turned the key and nothing worked. i figured i had got a defective starter but the second one would not do anything either. i got a cylinnoied switch. didnt change anything. i hooked up a push but to the switch and it will start and run as long as the switch is pressed in, but the starter stays engaged. i have changed all the fuses in the fuse box under the hood except a black ecc fuse.
