Diverdwn
- October 7, 2013
- Bradenton, FL
- 1998 Ford Ranger
I have a 1998 ford ranger 4 cyl, 5 speed with 133k miles that has an issue with starting when it's cold. There doesn't seem to be an issue when it's warm. I think its due to a choke issue but don't know enough about it to be sure or what to check. When starting it does crank but you need to work the gas pedal for it to continue running until it warms up, then it's fine.
I have replaced the Throttle position sensor as well as the Idle control Valve and removed the battery cable so the sensor would reset, and I still have the issue.
Also, I have noticed that sometimes the motor will rev and then drop to close to shutting down over and over again even if the gas pedal is pressed. It has done this to me at a stop light as well as a parking lot.
What do I try next?
What do I try next?
