Steering Arm Ball Joint Dodgy? | Ford Explorer Forums
kennyh
Glasgow, Scotland
'98 4.0i V6 Auto
Hi Guys
I'm replacing my lower ball joints and on putting things back together I've notice that my steering arm ball joint bolt spins, and as such I cant get the nut tightened.
I take it it need replaced? Or do I simply put a set of grips on the bottom of the bolt.?
Keep or replace??
Cheers
Kenny
Best bet is to use a 'G' clamp to wedge the taper down. Then do up the nut. If there is play in the joint then replace it.
