G
geoph1986
I have a quick question about the steering wheel on my X, but first a little history. About 2 months ago I replaced the steering box with a junkyard unit, that had the pitman arm still attached. Once I had completed the swap, my steering wheel sits like it's turned 90 degrees. At first it was fine, but now the look is really bugging me. Is there an easy way make the steering wheel sit straight or do I have to pull the pitman arm to do this? I would very much like to just pull off the steering wheel and put it on straight, but as I understand it, the wheel has flat spots with the splines so it only goes on in one position. Does anyone know of another Ford wheel that is splines all around that I could put on in any position? I don't care if the new wheel has the buttons for cruise or anything else. Thanks in advance for any insight.
