Andy97XLT
- December 6, 1999
- Kensington, Maryland
- '97 Frankenstein XLT
I've had this problem for sometime now. When turned fully to the right or left, my steering seems to whine as if the pump's low on fluid but it's not. Also, I notice, mainly when backing up, and the wheel turned almost fully to either direction, I hear a pop coming from the front end. It's not constant, just one time only. I wish I could be more specific, but that's exactly what's happening and what it sounds like.
I understand that the steering will whine a little when the wheel is cranked down upon but it does this as I'm approacing full right or left and as I get even closer to full turn, I then hear the pop.
The steering is always smooth at any speed but just a little loud.
Also, my front differential is leaking. It leaked once before while still under warantee and the dealer replaced the front seal between the diff and the front diff cover. Now, I'm afraid it's leaking from the rear where the driveshaft enters the diff. Replacing the front seal is not a big deal but how about that rear seal? I'm worried that the metal might be somewhat deformed around the seal area and even if a new rear seal is installed, it will still leak because the seal will not make up for the deflection of metal.
All suggestions and ideas will be MUCH appreciated.
Also, does anyone know of anyway of installing diff and transmission protectors/shileds on the 95+?
I'd like an undercarriage rock crawling protector package-some armor for those vital parts!
Is anything even available?
Happy Wheelin,
Andy Statland
'97 XLT 4.0L OHC 4Dr 4x4
Warrior Twist in the works
Happy Wheelin,
Andy Statland
