Sticking Throttle | Ford Explorer Forums
Sticking Throttle
chapsdeva
Richmond, Va
2015 Limited
My 2000 Explorer has recently developed a problem with the throttle sticking. I just cleaned the IAC valve, throttle body and lubed the throttle spring and cable....didn't help.....I'm still having the same problem. I'm guessing maybe the TP sensor is the problem? Any ideas? Thanks!
I had a similar problem, but mine was from oil getting in through the pcv system due worn rings.
