BonesDT
- July 12, 2002
- Westchester, NY
- Red '99 Sport SOHC 4x4
My throttle has been sticking right at the beginning. It's starting to really get to me at stops. I guess it's either the cable or the pivot pin in the throttle body is gunked up.
I tried the zip-tie throttle body mod, didn't help this issue. I tried to spray a lot of penetrating and lithium oil on the outside of the pin, but there are 2 springs blocking the way.
Can I rebuild the throttle body? Can the pin be unbloted out so I can clean it off? I don't see disassembly instructions in the factory repair manual. The manual also says:
CAUTION:
Throttle body bore and plate area have a special coating and cannot be cleaned, or possible damage to the throttle body may occur.
Any advice?
CAUTION:
Any advice?
