willrappold24
- July 9, 2012
- Virginia
- 1999 ford explorer
I have a 1998 ford explorer xlt V6 SOHC with a sticking throttle problem, sometimes when you first start it will idle fine then rev up to 1500 rpm and stay there until you cut it off, other times while driving it will stick ( can tell because car doesn't shift as well) and will keep up until you put it in park and cut it off. Sometimes will rev all the way up to 2500 rpm. Now it has cut the check engine light on but I have taken it to a couple different places and they can't find a code. Could it be the throttle position sensor or something else?
If it is the tps how do you change it?
thanks.
thanks.
