geosnooker2000
- March 29, 2007
- Somerville TN
- '10 Eddie Bauer V8 4x4
And getting depressed. I'm running out of Summer before school starts and my daughter needs this truck for commuting.
It's a '93 Explorer Sport manual tranny.
My main job I just finished (as some of you know) was a head gasket job that turned into replacing the heads (remanufactured from these guys http://cgi.ebay.com/ebaymotors/REBU...rQ5fTruckQ5fPartsQ5fAccessories#ht_1964wt_937)
because they were both cracked. After about 1 hour of a bad miss on an undetermined cylinder due to a clogged injector, it started running perfectly....... and then over heating. The same problem I had to begin with. I felt stupid after realizing I was running straight water and no thermostat. So yesterday I added almost a full gallon of full strength antifreeze. Of course there was room. I had just finished taking it on a 15 mile round trip to test the radiator. As usual it boiled over when I got back home (this normally only happens after the engine is turned off).
So as I said, I added the nearly 1 gallon and the new Thermostat. This morning I set out for the Mall, a 30 mile trip each way, at 10:30am. It was roughly 92 F. The temp gauge bounced around like it will do when it is working the air bubbles out, but it still seemed too high. When I arrived at the mall, it boiled over.
I didn't panic. I just checked it when I came out of the mall 2 hours later to find that the radiator was full and the overflow tank was completely empty. It had all sucked back in like it's supposed to. I added some cold water to the overflow tank up to the "cold fill" line and started home. It was +/- 100 F
I was very happy at first because I saw this time the temp gauge was rock solid at the "N" and didn't move for the first 10 minutes home. All the air bubbles were def. gone. Then it started to rise ever so steadily all the way home. There were no fluctuations. It was just a slow steady rise until I had to stop 15 minutes from home to let it cool down.
Guys, if it's not cracked heads, what could it be? I have flushed the crap out of this thing 3 or 4 times over the past 2 months trying to get all the "liquid copper" and rust out, and I thought I did a pretty good job. Could this be the symptoms of a worn impeller on the water pump? Any other ideas?
Or am I going to have to pull these freaking heads and get the shop to magnaflux them?
