outatime
- August 26, 2014
- davenport florida
- 2007 sport trac
Hi All, this is a last ditch effort to see if anyone can help me I have a 2007 4.6 Ltd , I still can't gas the truck up without it taking about 30mins or if I unplug the purge valve line from the tank it gases up perfectly.
The problem is with the EVAP system somewhere, when gas goes in there is a block stopping the fumes and it just splashes back and I get a sucking from the small pipe connected to the filler pipe.
So far I have replaced : purge valve front of engine, PCM,
Vapor Canister (Charcoal) filter, fuel hose and vapor Canister Vent solenoid. As you can see I have really tried my best and I am just out of ideas now. Its odd that if I disconnect the purge valve from the tank side it gases up just fine but I have the EVAP engine management light on all the time too. So frustrating.
Is there anyone who might have a solution for this issue please?
Thank you so much
Thank you so much
