still have PO401 code | Ford Explorer Forums
gile_82
Jay, ME
98 XLT SPORT
i have changed the DPFE, and the egr valve and cleaned the tube and it is still coming up with that code
im starting to get up set with it
do you get a P1408 in the KOER test?? if not, and the EGR valve is good, check passage ways are clear to both the intake and exhaust. if they are clear then the code may be intermittent.
if you apply 5in vac to the EGR valve does the engine stumble or die??
i clear out all the codes i have actron 2 scan tool
but ill check the vacuum lines
thanks guys
