- July 5, 2003
- Brockton, MA
- '93 XLT 4x4
Actually you don't need to cut the wire. The shift motor connector can be disassembled so you can remove any the wires without the need to cut them. You need a pic, small screwdriver or other such tool to remove the inner red lock ring inside the connector. Once removed you can free the wire from the connector.TAZZOUT said:: ...If you buy a new or used shift motor I guess you will need to cut that small wire and splice the new one on in order to replace your old one.
