brewsntattoos
- April 30, 2015
- 1999 Explorer
Hello all.
TL;DR at the bottom if you just want the quick and dirty.
Started about a week ago with my 1999 4.0 Explorer. Wouldn't start in the driveway one day, went and did a quick check on things, see if any plug wires were loose or off or if my air filter was bad. Tried it once more and it fired. A week later it did the same thing and I gave it a more of a good look. Ended up doing quick cheap fixes first like plugs and fuel filter and it fired up and ran for a day or two.
Then I was out running errands, stopped for 10 minutes and it was dead. Would not start up. I pulled my fuel line just after my filter and had a friend try and start it and no fuel was pumping out the filter at all. So I have it towed home and swap out the fuel pump, and it still won't start.
I checked my fuel pressure on the rail, was at 62 psi. I started checking my compression on the 3rd cylinder and was 135, then the second and it was 125. About that time my battery was starting to die, so we hooked it up with jumpers to another rig. Then a friend suggested I put the plug back and try priming it with a bit of gas in the air intake. So, I do, and it fires up, but wouldn't maintain and would die after a few seconds. We tried it a couple more times and got it to run for a second or two more while someone pressed on the throttle half open, but it would still quickly die out.
I'm a bit stumped at this point and not sure what is next. I am thinking it has to be something with the fuel rail or injectors, but I'm more of a carb guy and do not know my way around these systems very well.
TL;DR - Swapped out a fuel filter in my 99 4.0 Explorer. Pump works ( can hear it and see fuel squirt out the fuel line ) and have pressure on the rail at 62 psi. Started checking compression, and was suggested I prime it by pouring a little gas into the air intake. It started a few times, but only for a few seconds before dying. Not sure what is next.
