Fixed
Well, what can I say. Hope this info will help others who have fuel delivery issues. The problem was a weak fuel pump, probably also sucking in air, worse when under half tank. Some of the things that I did was to compare it's performance to my 97 aerostar. As stated before, I only got 3 or 4 ounce of fuel from the problem 96 areo, but i tried the 97 and got 12 oz in 15 secs. The pump, complete, was 120 , dropping the tank, a snap. 5 fasteners on the heat shield, 2 on the tank straps and one clamp on the fuel filler. Didn't even need any Jack to lower the tank. Did have one but removed it because this plastic tank with a couple gallons in it was not a problem. It was difficult to diagnose this issue since so many things can give you the symptoms. Plus with 14 year old aero that no one wants to service because it is difficult. Had 1 ase mechanic service it but was not addressing the issue successfully. At least now I do have new coil pack, probably the only item that was not bad,wires and plugs, water pump, new tps and act and great brakes all around. By the way, I did back the van onto my ramps to drop the tank, all went well. Thanks BrooklynBay for helping me narrow this issue down. I still believe the aerostar is the best work vehicle. Maybe i'll find the time to post pictures of my 3/4'' pipe rack the i've had on all three of my aeros that I have loaded to the max without problems. I'm talking 30 sheets of 1/2'' ply on my roof.Not to mention loads of treated 2x6 for decks. Just a carpenter in Texas. Dennis.......
