Stock body bolt is spinning freely, what to do? | Ford Explorer Forums
Brandon96
Central Virginia
'96 XLT 4.0 OHV
I'm in the middle of executing the Pa-883 body lift, I've gotten all the other body bolts loosened with a few threads backed into the frame to keep the body stable. All except for ONE, the bolt directly under the driver's side rear seat is spinning freely when i try to loosen it, it is also spinning the two rubber bushings below the frame bracket and the bushing/washer above the stock puck or spacer, for lack of better terms. My question is, in which object are the threads that the body bolt screws into so I know what to hold in place so I can remove it. Are they in the frame? meaning i've stripped the crap out of them, or are they in the rubber bushings below the frame? I've tried a few things to no avail.
Nevermind, Sawsalled the inner fender wall out, got to the bolt, sawed it in half.
