Stock ride height? | Ford Explorer Forums
Stock ride height?
POS Camaro
Groton, CT
1999 XLT
What should the stock ride height be? Right noew the front is at 32" from the ground to the center of the wheel well and 31" to 31 1/2" for the rear. It looks retarded with the ass sagging like that.
I'm making the assumption that the rear springs are worn out and need replacement.
All Explorers are a little different. The leaves tend to flatten over time. An add-a-leaf, or a pair of shackles should lift it right back up. If you look at it from the rear you'll probably see it's not just sagging in the rear, but also to the drivers side, as well.
