MotorCityFats13
- January 25, 2015
- Flatrock MI
- 2007 Explorer XLT 4.0L
after my first set of front links ate the bushings after maybe 3 years I decided to try to find an "energy suspensions" solution and I dug up that the links are the same as a 94-01 dodge ram but those links are only offered in a kit including the sway bar bushings and those dont work with the 32mm ford sway bar so..... what I found is that you can buy the cheap ebay replacements for $12 a pair and purchase the energy suspensions performance end link bushings set "9.8105R" red or "9.8105G" black for $15 which seems to be a regularly stocked item as the parts stores
my bracket bushings were very loose and worn out so I replaced them with the generic federal mogal part so only time will tell if this will be my perfect solution I been digging to find
if my rears eat them selfs Ill work on those next
