Jason94sport
- April 30, 2001
- FL
- Sold
Started Sunday night. Seems my throttle sticks. I'll be going 65, shift into N yet my rpm's will still hover around 2000 rpm. I tap the gas, then it goes down. Also if i'm in gear, the truck will still accelarate even if I'm not pressing the gas & again the RPM's will stay around 2000. However this is only happening sometimes. Maybe 8-10 times since Sunday. Strange. I scanned for codes, & none were found. Speed sensor? IAC? I lubed the trottle cable at the TB. The TB, TPS, & MAS are new, & my X ran fine untill Sunday. The only thing that was changed in the last few weeks has been the brakes. I put new lines, ART rotors, new calipers, pads, rear drums, shoes, & bleed them. Does it in all gears too. I have a 5 speed. Shifts fine, no noise, clutch is good. Any ideas??
