SploderXLT
- July 11, 2006
- Richmond, VA
- 99 XLS
Maybe someone here can offer some help. Everything was pretty much fine until I put a limited slip rear in mtruck. after that It was difficut to make tight turns. within a few days of putting the axle under the truck, the transfer case took a dump. Installed another transfer case and same thing... Brown wire mod doesnt work and even if I disconnect the harness to the shift motor, its still in 4wd. pulled the shift motor off and there are 3 settings, 4hi, N, 4lo. when switched to 4hi and 4lo the front a rear driveshafts are locked with the input shaft, when shifted to N the front and rear driveshafts are still locked, but now they are free from the inputshaft. What am I missing.
its a 99 4.0 with auto/4hi/4low switch
