dan668
- July 15, 2011
- 2002 4.6L Exploder
Upon idle, my 2002 limited v8 explorer starts to stutter and at times did stall. It gave me codes and a service engine icon on the dash. The codes were for the o2 sensor and some bank codes. Which neither were the issue, i found the fix, it was the pcv hose, the elbow had a hole in it. I replaced that it it was good to go. Drove fine for a few months.
Now, another issue has arose. It stutters when idle, sometimes enough to stall. And upon accelerating, it sometimes hangs for split second and stutters and a chime comes from the dash, but no lights come up on the dash. No codes, even when checked by a pro scantool. I changed the IAC and the pcv valve. It worked, no issues for 2 weeks. I take the explorer out today, and the same issues are back. Where should i start? No codes again. Ive cleaned the TB, cleaned the MAF and visually inspected the other hoses.
